Error Code: 0x80073CF9
I am not able to download Asphalt 9 from Microsoft Store. It shows Error Code: 0x80073CF9. I am on Windows 11 but I also faced this problem when I was on Windows 10. Please help.
The error Screenshot-->
System info-->
Processor Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz 2.11 GHz
Installed RAM 8.00 GB (7.83 GB usable)
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Windows info-->
Edition Windows 11 Home Single Language
Version 21H2
Installed on ‎01/‎07/‎2021
OS build 22000.100
Experience Windows Feature Experience Pack 421.18901.0.3
Thank you for writing to Microsoft Community Forums.
We understand the concern as you are trying to install Asphalt 9 on Windows 11.
In this scenario, we would like you to sign-out from Microsoft Store and perform the below steps and later sign-in back with the Microsoft Account.
Step 1: Reset the Windows Store Cache
Press the Windows Logo Key + R to open the Run dialog box, type wsreset.exe, and then select OK.
Note: A blank Command Prompt window will open, and after about ten seconds the window will close and Microsoft Store will open automatically.
Step 2: Run the Windows Store Apps Troubleshooter
Select the Start    button, and then select Settings> System > Troubleshoot > Other Troubleshooters, and then from the list select Windows Store appsRun the troubleshooter.
Step 3: Running PowerShell Command
  1. Press Windows + X key and select Windows PowerShell (Admin).
  2. Copy and paste this command, then press enter: Get-AppXPackage *WindowsStore* -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register “$($_.InstallLocation)\AppXManifest.xml”}
  3. Restart PC and check
Aditya Roy
Microsoft Community – Moderator
I performed the steps but the problem still exists. Also the Troubleshooter showed a issue which it could not fix.
Last updated July 13, 2024 Views 688 Applies to:
