I hope I am posting this is the right place, since DX 12 Ultimate is Windows 11 which is in preview only.
I hope the title explains the issue, please help!
Thanks
Thanks
Thank you for writing to Microsoft Community Forums.
In order to get clarity and to assist you accordingly, please reply with the answers to the questions below:
What is the Windows 10 Version and Build installed? (Type winver in Windows search/Run command)
What is the make and model of the PC/motherboard?
Do you have any dedicated graphics card?
Are you aware of any changes on the PC prior to this issue?
You might consider upgrading your hardware. You might also need to turn on graphics acceleration. Refer to the below links for details on the same and check if this helps -
DirectX Frequently Asked Questions - Win32 apps | Microsoft Docs
DirectX 12 Ultimate Getting Started Guide | DirectX Developer Blog
Microsoft Announces DirectX 12 Ultimate: A New Standard for Next-Gen Games, Supported by GeForce RTX
Aditya Roy
Microsoft Community – Moderator
·Was this reply helpful?
DirectX Ultimate may not be supported by your gfx chipset.
For further reading, please refer to :
I have MSI Nvidia GeForce GTX 1050 Ti as gfx card and DirectX Ultimate is disabled in Dxdiag diagnostic tool, either.
I checked "Hardware Accelerated GPU Scheduling" in Settings > System > Display > Graphics > Change Default Graphics Settings and it was already turned on, but it was of no help, either.
Hope this helps.
20 people found this reply helpful
I have an NVidia GTX 1650 and have the same issue. Shows disabled in DiaxTool.
Have rebuilt my system drivers and firmware on the motherboard, video card and all other peripherals.
Motherboard MSI B550
Video Card NVidia Geforce 1650 4.
Driver 30.0.14.7141
Processor AMD Ryzen 7 3700X 8-Core Processor 3.60 GHz
Installed RAM 64.0 GB
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
NVIDIA System Information report created on: 07/24/2021 19:38:54
System name: DESKTOP-6B7IT8E
[Display]
Operating System: Windows 10 Pro, 64-bit
DirectX version: 12.0
GPU processor: NVIDIA GeForce GTX 1650
Driver version: 471.41
Driver Type: DCH
Direct3D feature level: 12_1
CUDA Cores: 896
Core clock: 1695 MHz
Memory data rate: 8.00 Gbps
Memory interface: 128-bit
Memory bandwidth: 128.03 GB/s
Total available graphics memory: 36827 MB
Dedicated video memory: 4096 MB GDDR5
System video memory: 0 MB
Shared system memory: 32731 MB
Video BIOS version: 90.17.2A.00.E5
IRQ: Not used
Bus: PCI Express x16 Gen3
Device Id: 10DE 1F82 400E1458
Part Number: G174 0000
13 people found this reply helpful
I have gtx 1660 super directx 12 is still not enabled.I also keep updating the dxdiag driver.
So I did a lil search and realized that direct x ultimate is supported by only nvidea rtx cards and some latest amd video cards
81 people found this reply helpful
intel uhd doesn't support direct x 12 ultimate. this direct x only support for RTX series 20/30
31 people found this reply helpful
only for rtx series
Everyone who does not have an RTX graphics card will not show DX 12 Ulitmate enabled. You must have an RTX GPU.
29 people found this reply helpful
Okay so I have an RTX 2060 TI and its disabled. How would I enable it?
79 people found this reply helpful
