20H1 Build 18936 is Live
Downloading now.
Was this discussion helpful?
CET, MCC 2011
Old Mig15 Pilot
Google's 'Grace Hopper' undersea cable just landed in the UK
There could be a very interesting time for some of us with this build.....?
A limited number Insiders attempting to install Build 18936 may experience install failures with error code c1900101 due to a compatibility bug with a storage driver on their device.  The device will attempt to install, fail, and successfully roll back to the currently installed build on the device. Attempted re-tries to install the build, either manual or automatic, will not bypass this issue.  A fix is forthcoming, but there are no known workarounds currently. Note: By default, the update will attempt to install (3) times.  Users may pause updates if they experience this issue and want to bypass the re-try attempts.
Old Mig15 Pilot
Downloading now.
Thanks CK, I was dozing off. lol
Windows 10/11 Insider since 10/02/2014
Never Give Up!
Thank you CK. Making ISO, any word for Slow 19H2
Johnny
Completed a clean install of 18936 to a partition on my NVMe SSD.
Will try Windows Update on a VM next.
Don
2012 Alienware Aurora R4 ALX
Intel i7-3960X, 32GB RAM, 250GB NVMe SSD, NVIDIA GeForce GTX 690
My Laptop got all the way to configuring updates
before it rolled back to 18932 with 0xc1900101 error.
"A limited number Insiders attempting to install Build 18936 may experience install failures with error code c1900101 due to a compatibility bug with a storage driver on their device."
As demonstrated in the past (not once but 3 times), neither a compatibility bug or having an storage device mounted or inserted made a difference IF the Windows Search Service was disable prior to attempting the update but I don't know the result this time around yet...
"Attempted re-tries to install the build, either manual or automatic, will not bypass this issue."
During those past failures, a second try and/or a manual update from ISO did work so it'll be interesting to find out if the warning is actually true this time around.
https://answers.microsoft.com/en-us/insider/forum/all/workaround-to-avoid-error-0xc1900101-before/96d91cc4-2ca5-4537-9334-a3a066d217da
Up and running after approx. 60 minutes. Hope you are not going to be one of the unlucky ones CK.
Old Mig15 Pilot
Last updated February 2, 2021 Views 2,614 Applies to:
