Dear,
My Internet Explorer 9 has several technical issues of which I do not know how to solve them. The first problem is that Internet explorer 9 does not seem to recognize Adobe flash player and Silverlight. Of both, Adobe flash player and Silverlight, the newest version is installed on my computer. The strangest things is that IE9 sometimes does recognize Adobe flash player as well as Silverlight. I barely have installed any add-ons, which makes it unlikely that an add-on is the problem. Till now I have done a couple of things;
1. Reinstalling Internet Explorer 9(resetting IE9)
2. Deleting Adobe Flash Player and reinstalling it(according the way Adobe presripes it)
3. Try to watch sites in compatibility view
My second problem is that Internet Explorer 9 crashes a lot which ,most of the time, goes together with the following message; Cannot load library for language 'Jscript Author' path 'C\Windows\system32\jscript.dll' please contact Kaspersky lab for the solution. (err.0000045A)
Personally I think the problem has occured sometime during the installation process of Internet Explorer 9 or the Beta. However I do not know how to solve this. Please could someone help me solving this problem?
Thanks in advance!
