Hello Don,
Thank you for visiting Microsoft Community and providing us with the detailed description about the issue.
As per the description, I understand that you want to know how to refresh the cache in Edge on the system.
I certainly understand your concern and will try my best to help you.
I would suggest you to try the following steps and check if that helps.
First of all launch Microsoft Edge Browser.
After that click on “More action” option which is visible at top right side of the browser and you will see “Settings” option.
Under “Settings” scroll down and you will see a button “Choose what to clear” under “Clear browsing data” option.
Once you click on this option you will see list of feature like
Browsing History
Cookies and saved website data
Cached data and file
Download history
Form data
Password.
Here you need to check the option you want to clear and click “Clear” button and you’re done.
For more information:
I would suggest you to refer to the suggestions provided by
“Andre Da Costa” replied on January 22, 2015 in the following Microsoft Community link.
Frequently Asked Questions: Windows 10
http://answers.microsoft.com/en-us/insider/wiki/insider_wintp-insider_install/frequently-asked-questions-windows-10/5c0b9368-a9e8-4238-b1e4-45f4b7ed2fb9
I hope this information is helpful.
Please do let us know if you need any further assistance, we will be glad to assist you.
Jayant
