Surface Book and Mixed Reality ... USB 3.0 Ports of Surface Book sucks
Please fix this problem ASAP Microsoft.
If a Mixed Reality Headset is connected directly to the Surface Book's USB 3.0 ports, Windows 10 is not able to recognize the device.
If you use a USB 3.0 Hub, then Windows 10 is able to recognize the Headset.
Something is clearly messed up with the USB 3.0 port drivers on the Surface Book.
I am using a HP Mixed Reality, but this seems to be a general problem: https://forums.hololens.com/discussion/8040/getting-a-usb-device-not-found-when-plugging-my-acer-into-my-surface-book
Informationen zur Frage
Letzte Aktualisierung am 28 September, 2018 Aufrufe 349 Gilt für:
Antwort
Antwort
Ok, I solved the Problem.
Go to Regedit.exe search for
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{36fc9e60-c465-11cf-8056-444553540000}
and delete the value of LowerFilters  (only the value not the key LowFilters)
reboot everything works great!
I think the problem occurs when the SurfaceDockUpdate tool is installed.
O.k. ich habe das Problem gelöst.
Gehe zu Regedit.exe Suche nach HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass {36FC9E60-C465-11CF-8056-444553540000}
und lösche den Wert von LowerFilters (nur der Wert nicht der Schlüssel LowFilters)
Reboot alles funktioniert großartig!
Ich denke, das Problem tritt auf, wenn das SurfaceDockUpdate-Tool installiert ist.
Für 4 Personen war diese Antwort hilfreich
Vielen Dank für Ihr Feedback.
