Hello Bruno,
Surface Arc Mouse would support middle-click when you download and install the
Mouse and Keyboard Center (MKC) to allow you to change the default assignments for it and other DPI configuration. You
can set the Three Finger Click Functionality as your middle-click button.
The settings below are the things you can change in MKC:
Mouse Scrolling Sensitivity
Disable or Enable Horizontal/Vertical Scrolling
Reverse Scrolling Direction
Feedback for identifying programs that don’t scroll correctly.
For more information about Microsoft Surface Arc Mouse, you may click
here.
If you would like me to provide additional advice, simply respond to this thread. I will get notified and I’ll reply to you as soon as I can.
Regards.
