Question
  • This thread is locked from future replies
What is in the 12/17/2015 update for Surface Pro 4?
fatou8 asked on
8 people had this question
Abuse history
The answered status icon Answer
Clare_Hs replied on
Hello Fatou8,
The following updates will be listed as “System Firmware Update – 12/17/2015” or “System Hardware Update – 12/17/2015”  within the Windows Update History.
  • Surface Pro 4 Firmware Update (v1.1.420.0) enhances stability with Surface Pro 4 Type Cover.
Note   When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update then please manually check Windows Update later.
 *In addition, please check out the Surface Pro 4 update history page for more details on all previous updates.
Having trouble downloading or installing from Windows Update?  Please try to manually download and install the update - for instructions see https://www.microsoft.com/surface/en-us/support/performance-and-maintenance/install-software-updates-for-surface.
Kind regards,
Clare
12 people found this helpful
Abuse history
Clare_Hs replied on
Hello Fatou8,
Kind regards,
Clare
Abuse history
