How to get rid of the surface pen visual pointer (dot) on the screen?
Does anyone know how I can turn off the visual pointer (visual dot) that shows up on the screen once the surface pen is writing on the screen. I record lectures using Camtasia and Powerpoint and visual dot from the pen shows up on the screen while writing
and is rather annoying - people know where they are on the screen with the tip of the pen. I tried checking the settings for the pointer under settings and it was not helpful.
Thanks in advance for anyone who can help. If this cannot be done and Microsoft is viewing this...can you add a surface update that allows users to off the visual pointer so people don't have look at it this visual cursor or dot while using the pen? Thanks.
