Surface 2 Overheating
I have been using my Surface 2 for a week now and everything has been great except when I play Halo: Spartan Assault. The back gets pretty hot while playing (which I don't mind) but then my Surface automatically dims the screen to the lowest level. I have to pause and wait for the Surface to cool down before playing again. This is unacceptable to me. Has anyone else had that problem? I'm worried it is a defective Surface 2 or worse, all units can overheat. I'm playing in a cool environment without the screen turned up to full brightness too. Please help.
Hello aperson_
Are you still experiencing this issue?  Have any of the troubleshooting steps helped?  Any additional details?
If this continues, you may wish to reach out to Support.
Best regards
Greetings all,
Surface devices may dim the screen as thermal temperatures rise from extended, high CPU intensive activities-- like gaming.  In some scenarios this does not appear necessary.  Our top priority is for customers to have the best possible experience on their Surface device.  We’re working on a tuning update that will remove this unnecessary dimming event.  You can expect this update in an upcoming Windows Update package.  In the meantime allow the Surface to cool down for a minute or so in order to return the screen to previous brightness levels.
Thank you for posting,
Steven B
Last updated June 1, 2022 Views 7,188 Applies to:
