Microsoft Security Essentials
  • Getting Started and Upgrading
  • Microsoft Security Essentials
  • All forums
Question
Uninstalling MSE
Typically, Microsoft Security Essentials can be removed by going to Control Panel - Programs and running the uninstall there.
However, there are times when this won't work.
Official Solution:
Microsoft has published a knowledgebase article for how to manually remove Microsoft Security Essentials version 2.x: http://support.microsoft.com/kb/2483120
Microsoft has developed a Fix-It for cleaning up/removing  Microsoft Security Essentials Version 1.x. More information here: http://support.microsoft.com/kb/2435760
(The version of MSE can be found by opening Microsoft Security Essentials and clicking the down arrow to the right of Help in the upper right of the main program interface, then selecting About… Version 2 was released at the end of 2010. All new installs after that time would be version 2.x and older versions should have been upgraded beginning in January of 2011. Version 4 was released at the end of April 2012)
The following was added 5/7/12 based on a reply from Support to address removal of MSE to resolve issues with a failed upgrade from 2.x to v4:
The following is the uninstall part of what MS Support provided when responding to an inquiry where uninstalling was a problem and our normally recommended procedures were not working.
Use our FixIt Tool to uninstall Microsoft Security Essentials.
This tool is designed to fix un-installation issues like, MSE registry issues, removes remnants of Microsoft Security Essentials from your computer.
a. To do this run the FixIt tool from the following links.
b. Click the below link and select Run Now button.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
c. After downloading and running for the first time
d. Select Run on small pop-up window and select Run on Internet Explorer-Security Warning Window.
e. Select Detect problems and let me select the files to apply.
f. Select Uninstalling.
g. After detecting problems Select Microsoft Security Client to uninstall and click Next.
h. Repeat the steps from b to f and, this time select Microsoft Antimalware from list to uninstall and click Next.
i. Restart your computer and reinstall Microsoft Security essentials.
If that doesn't work, please proceed with the advanced removal process:
Further down is a set of commands which will be executed automatically in the background. You need to save this file as "mseremoval.bat" on desktop and run that batch file.
msremoval.txt is given at the end of the post - copy and paste into notepad and follow above information
Uninstall and removal of Microsoft Security Essentials files and folders using advanced method
a. Right click on the attachment and select SaveAs.
b. In the File Name section, enter the name as "mseremoval.bat" with quotes and click Save.
c. In the Save As Type, select All Files.
d. Right click on mseremoval.bat and select Run.
e. A command prompt window will open and then close when the registry updates have completed, once this window closes you can delete the mseremoval.bat file that you created earlier in these steps
f. Restart and reinstall Microsoft Security Essentials.
**** MSREMOVAL.TXT **** (don't copy this line but do copy everything below)
cd /d "%ProgramFiles%\Microsoft Security Client"
setup.exe /x
TASKKILL /f /im MsMpEng.exe
TASKKILL /f /im msseces.exe
net stop MsMpSvc
sc delete MsMpSvc
REG DELETE "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\MsMpSvc" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft Antimalware" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft Security Client" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Microsoft Antimalware" /f
REG DELETE "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Current Version\Run\MSC" /f
REG DELETE "HKEY_CLASSES_ROOT\Installer\Products\4C677A77F01DD614880F352F9DCD9D3B" /f
REG DELETE "HKEY_CLASSES_ROOT\Installer\Products\4D880477777087D409D44E533B815F2D" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft Security Client" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{774088D4-0777-4D78-904D-E435B318F5D2}" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{77A776C4-D10F-416D-88F0-53F2D9DCD9B3}" /f
REG DELETE "HKEY_CLASSES_ROOT\Installer\UpgradeCodes\1F69ACF0D1CF2B7418F292F0E05EC20B" /f
REG DELETE "HKEY_CLASSES_ROOT\Installer\UpgradeCodes\11BB99F8B7FD53D4398442FBBAEF050F" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\4C677A77F01DD614880F352F9DCD9D3B" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\4D880477777087D409D44E533B815F2D" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\11BB99F8B7FD53D4398442FBBAEF050F" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\1F69ACF0D1CF2B7418F292F0E05EC20B" /f
takeown /f "%ProgramData%\Microsoft\Microsoft Antimalware" /a /r
takeown /f "%ProgramData%\Microsoft\Microsoft Security Client" /a /r
takeown /f "%ProgramFiles%\Microsoft Security Client" /a /r
REM Delete the MSE folders.
rmdir /s /q "%ProgramData%\Microsoft\Microsoft Antimalware"
rmdir /s /q "%ProgramData%\Microsoft\Microsoft Security Client"
rmdir /s /q "%ProgramFiles%\Microsoft Security Client"
REM Stop the WMI and its dependency services
sc stop sharedaccess
sc stop mpssvc
sc stop wscsvc
sc stop iphlpsvc
sc stop winmgmt
REM Delete the Repository folder.
rmdir /s /q "C:\Windows\System32\wbem\Repository"
sc stop
EXIT
**** MSREMOVAL.TXT **** (don't copy this line but do copy everything above)
There are two manual removal methods that you can try:
Alternate solution #1
The following information was provided by forum user, Aiscer, to assist in removing MSE if using Control Panel/Programs does not work properly:
1. Download the MSE installer for your Operating System from the Home Page:
Note: Editing the registry incorrectly can cause your system to become unusable. Proceed with caution.
Use the Registry Editor to delete the following key from the Registry.
On XP, go to Start, then Run, and type:
    Regedit.exe
Press Enter
On Vista/Windows 7, in the Search box above the Start "orb" type:
    Regedit -don't press enter.
Right click regedit.exe in the results list above and select, "Run as Administrator"
Navigate to:
     HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft Security Essentials
by expanding the branches in the left pane until the branch forMicrosoft Security Essentials is displayed.
Right click "Microsoft Security Essentials" in the left hand pane and select Delete.
Close the registry editor.
Then:
XP:
Click on the Start Menu, go to All Programs, Accessories, Command Prompt
A “DOS” window opens
Assuming that your system drive is C: -
At the prompt, type:
    CD C:\program files\microsoft security client\backup\x86
Press Enter
Type:
    setup.exe /u
Press Enter
Setup will launch and will uninstall MSE
Vista and Windows 7:
Type command in the search box (above the Start “orb”), do not press enter
In the results list above, under Programs, right click Command.exe and select "Run as Administrator"
Approve the action via the UAC prompt, if it appears.
A “DOS” window opens.
     CD C:\Program Files\Microsoft Security Essentials\Backup\x86  (for 32 bit Windows)
     CD C:\Program Files\Microsoft Security Essentials\Backup\amd64  (for 64 bit Windows)
Press Enter
At the prompt (c:\Program Files\Microsoft Security Essentials\Backup\x86> [or amd64>]), type:
     Setup.exe /u
Press Enter
Finally, if none of the above help, open a Support case.
To open an email support case, start here:https://support.microsoftsecurityessentials.com/
-steve
    • Child exploitation or abuse
    • Harassment or threats
    • Inappropriate/Adult content
    • Nudity
    • Profanity
    • Software piracy
    • SPAM/Advertising
    • Virus/Spyware/Malware danger
    • Other Term of Use or Code of Conduct violation
15 People had
this question
Stephen Boots
Community Moderator
Microsoft MVP Windows Live
Message marked as answers cannot be deleted
To delete this message, first unmark this message as an answer, then delete it.
Reason to remove escalation
Merge
Enter the thread ID of the thread you are merging into
Reply will be posted to a public thread
You are replying to a public portion of this thread. To reply privately, click Cancel, click the Private Messages tab, and Reply on that private message.
Don't show this message again
To report abuse, sign in or continue without signing in
Abuse type:
Details (optional):
Abuse type:
Details (required):
Enter the characters you see (required):
Type the numbers that you see in the picture.
Play audio and type the numbers that you hear.
Show a different picture.
Sign in
Hotmail, Xbox Live, Messenger, or msn accounts will also work.
Don't have one of the above accounts?
Signing in...
This page will automatically update after you are signed in.
If you are having problems, you can close this message and try to connect again.
