Error Messages: (1) 0x80070715 and (2) 0x8004FF0B
There are two ways that we can remove MSE. The first was alluded to before in one of the threads and the other one is running a cleanup tool and they vary in difficulty.
First:
1. Download the *OneCare cleanup tool:
http://go.microsoft.com/fwlink/?linkid=81699
2. After the tool runs if it prompts for a reboot please do so.
3. Reinstall MSE.
Second:
1. Download MSE from the website and save the file on the Desktop.
2. Open Command Prompt through RUN or Start Search by typing CMD hit enter. If you are using Vista right click on CMD and select "Run as Administrator".
3. In the Command Prompt console type: CD %USERPROFILE%\Desktop <- Hit ENTER
4. Type: msse <- then hit the TAB button.
5. Depending on your Operating System, after hitting tab it should either appear as any of the three below:
mssefullinstall-x86fre-en-us-xp.exe
mssefullinstall-x86fre-en-us-vista-win7
mssefullinstall-amd64fre-en-us-vista-win7.exe
6. Now put a space in between the whole line and put /U as seen below:
mssefullinstall-x86fre-en-us-xp.exe /U
mssefullinstall-x86fre-en-us-vista-win7 /U
mssefullinstall-amd64fre-en-us-vista-win7.exe /U
7. Hit ENTER and this should uninstall Microsoft Security Essentials.
8. After the uninstall you can now attempt installation. It would be best that you restart your system first after the uninstall.
*this tool is for OneCare but works also in removing other MSE components and entries which will enable re-installation of MSE.
Crimson Spectrum at http://aiscer.spaces.live.com
