Microsoft Security Essentials
  • Getting Started and Upgrading
  • Microsoft Security Essentials
  • All forums
Question
i am having aan problem with Microsoft Security Essentals. "isn't monitoring the comupter because the program's service stopped. "
that what is says in my computer.
    • Child exploitation or abuse
    • Harassment or threats
    • Inappropriate/Adult content
    • Nudity
    • Profanity
    • Software piracy
    • SPAM/Advertising
    • Virus/Spyware/Malware danger
    • Other Term of Use or Code of Conduct violation
2 People had
this question
Was this helpful?
What operating system?
What was the previous security software? Was it uninstalled? Did yo use a cleanup tool from the vendor?
The following may help:
You might receive a message in the Microsoft Security Essentials Windows notifying you that Microsoft Security Essentials isn't monitoring your computer because the program's service stopped. You should restart it now.
Step 1: Restart your computer.
Step 2: Make sure the Microsoft Security Essentials service is set to automatic and started
  1. In Windows XP, click Start , click Run , type services.msc , and then press ENTER .
    –or–
    In Windows Vista and Windows 7, click
    Start , click in the Start Search box, type services.msc , and then press ENTER .
  2. Search for Microsoft Antimalware Service . Right click it and select Properties or double-click it to open the service.
  3. Check to make sure that the " Startup Type " is set to " Automatic ".
  4. Click the Start button to start the service. If the Start button is not available, click the Stop button, and then click the Start button to restart the service.
  5. Make sure you note any errors that may appear during this process, submit a case online, and include the error information.
Step 3: Remove any existing Internet security programs
  1. In Windows XP, click Start , click Run , type appwiz.cpl , and then press ENTER .
    –or–
    In Windows Vista or Windows 7, click
    Start , click in the Start Search box, type appwiz.cpl , and then press ENTER .
  2. In the list of installed programs, uninstall any third-party Internet security programs.*
  3. Restart your computer, and then try to install Microsoft Security Essentials again.
Note:
*Some Internet security applications do not uninstall completely. You may need to download and run a cleanup utility for your previous security application in order for it to be completely removed.
Caution:
When you remove Internet security programs, your computer is unprotected. If you have problems installing Microsoft Security Essentials after you remove existing Internet security programs, contact Microsoft Security Essentials Support immediately by submitting a case online (see How to submit a case online for details).
Step 4: Uninstall/re-install Microsoft Security Essentials
  1. In Windows XP, click Start , click Run , type appwiz.cpl , and then press ENTER.
    -or-
    Start , and in the Start Search box, type appwiz.cpl , and then press ENTER.
  2. In the list of installed programs, click Microsoft Security Essentials , and then uninstall it.
  3. If prompted, restart your computer, and then try to install Microsoft Security Essentials again.
If the above steps do not solve your problem, you can always reinstall Microsoft Security Essentials and contact Microsoft Security Essentials email support .
-steve
~ Microsoft MVP Windows Live ~ Windows Live OneCare| Live Mesh|MS Security Essentials Forums Moderator ~
    • Nudity
    • Profanity
    • Software piracy
    • SPAM/Advertising
Stephen Boots
Community Moderator
Message marked as answers cannot be deleted
To delete this message, first unmark this message as an answer, then delete it.
Reason to remove escalation
Merge
Enter the thread ID of the thread you are merging into
Reply will be posted to a public thread
You are replying to a public portion of this thread. To reply privately, click Cancel, click the Private Messages tab, and Reply on that private message.
Don't show this message again
To report abuse, sign in or continue without signing in
Abuse type:
Details (optional):
Abuse type:
Details (required):
Enter the characters you see (required):
Type the numbers that you see in the picture.
Play audio and type the numbers that you hear.
Show a different picture.
Sign in
Hotmail, Xbox Live, Messenger, or msn accounts will also work.
Don't have one of the above accounts?
Signing in...
This page will automatically update after you are signed in.
If you are having problems, you can close this message and try to connect again.
