• September 11, 2016
    Announcement: Welcome to the updated Office forum
    Effective September 10th, Office, Office for Mac*, and Office 365 for business* forums are consolidated into a new, single Office forum category. We are excited for this change to further simplify community support for all Office customers, regardless of version or subscription method. Besides the forums consolidation the forum topics within the Office category were organized first by services, applications, and key topics, next by platform or device, and finally by Office version.
    Want more information on these changes? Check out this video, review the FAQ, or join the conversation in the Community Participation Center forum.
    We look forward to your Office questions, participation, and expertise in this new forum.
    *Forum topics available in limited languages.
Question
icloud settings does not work for outlook 2016 for win
YixiangXu asked on
I have just upgraded to office 2016 for win/pc.
I found out the icloud panel won't set properly for outlook 2016 which is essential for my work.
I need to use outlook to sync with icloud calendar and mails etc.
Could microsoft solve this asap?
thanks
80 people had this question
Abuse history
Roady [MVP] replied on
There is nothing to solve for Microsoft here. Apple still hasn't updated their iCloud application and add-in for compatibility with Outlook 2016.
Contact Apple support and ask them when they plan to release a version that is compatible with Outlook 2016.
Robert Sparnaaij [MVP-Outlook]
http://www.howto-outlook.com
http://www.msoutlook.info
8 people found this helpful
Abuse history
YixiangXu replied on
Just curious to ask then. Since outlook.com is claimed to be an exchange server, I failed to set it on a mac os as s.outlook.com does not work on their mail/calendar/contacts accounts.
Could you comment on that?
Be the first person to mark this helpful
Abuse history
Outlook.com isn't hosted on Exchange yet, that is currently still in a closed Preview stage.
If your client supports Exchange ActiveSync (EAS) connections, then you should be able to configure it with m.outlook.com as the mail server.
Abuse history
Thanks Roady. I have another question. From my knowledge, outlook.com have been in the process of being migrated to exchange online. It seems that my account looks like an exchange online but i can't set the exchange account on mac.
I am just curious to know how to you know if your outlook.com account has been successfully migrated to an exchange server? They say that all users will be upgraded to exchange online. Any signs or confirmation of completion?
thanks
Abuse history
Jim_Kirk replied on
thanks
Same problem here and same finger pointing answers.
Best solution, and I'm using it, install companionlink on win pc where outlook is and sync to dejacloud ( see http://www.companionlink.com/).  Install dejaoffice (Apple iOS app ) and all outlook stuff is on apple device in dejaoffice app folder on pad and phone.
Jim Kirk
Abuse history
In the top left corner, you'll see "Outlook Mail (Preview)" label.
As I mentioned before, it is still in a closed Preview stage. Once the Preview opens up, it is expected that it will still take about half a year to migrate all the mailboxes.
Abuse history
Thanks so much for your reply. Can I ask one more thing, does outlook 2016 for win support multiple exchange accounts?
If so, does the two accounts will interfere with calendars and contacts?
What I am asking is that after outlook.com becomes exchange online, will it crash with my existing company exchange mail account, in particular the calendars and contacts?
Jordan
Abuse history
Jim_Kirk replied on
Hi Roady,
Doesn't sound like your comment was directed to me but I'll expand a little on my previous answer.
I"m just a simple end user who upgraded to Outlook 2016 from Outlook 2013 on one of my two PC's.  On that PC, with O2013, I was using iCloud to sync to my iPad(Air2) and iPhone (6 Plus).  O2013 data synced well between the native IOS Calendar and Contact app and the Win 10 Pro O2013 desktop computer.  At this point I installed O2016 but iCloud sync was gone.  It didn't work.  So I had a problem.  Did a lot of research on the problem and it looked like iCloud to O2016 syncing was permanently going to remain broken.
I then went back to my other PC, running Outlook 2013, installed CompanionLInk(Ver 7) and got O2013 syncing with DejaCloud.  Changes on the ipad or iphone show up on the PC and vice-versa (using the DejaOffice app on the Apple Devices-not the native "Contacts" and "Calendar").  Looked good with syncing using O2013.  I then upgraded this machine to O2016 and DejaCloud sync kept working fine.  Good solution for me.
So I upgraded the first box to Companionlink syncing to DejaCloud.  O2016 was now working fine on the first box, thru DejaCloud, with the PC, ipad and iphone.
Now both boxes, running W10 Pro and O2016, using Dejacloud are working fine.  This gets me back in business now so it was a good solution for me.
I purchased the two year prepaid Companion Link-Dejacloud plan and this also allows my wife's W10 Pro box to use the same solution with her ipad and iphone (setting up a different Dejacloud username for her).
Jim
2 people found this helpful
Abuse history
Hemmer.Felix replied on
https://support.apple.com/en-au/HT204230
"Windows 10 currently isn't supported with iCloud for Windows"
Abuse history
jafergusonuk replied on
Yet it works perfectly on my desktop running Office 2016 under Windows 10. Oddly though I cannot get iCloud to run on my Surface Pro 3 running exactly the same apps. How weird is that?
1 person found this helpful
Abuse history
